Re: Another "OMG circular saw accident" in an odd location.
Hello Im new I know.
How would this repair be any different then a Tear or crack in the boat ? how would you fix this ?
I like the Boat. I was in your same boat last year when I started. Never fiberglassed before but was very mechanically knowledgeable. I will say this it really is not going to be that hard to fix. Only because I did the same thing, not quite as big but same concept. Here is a recomendation that I got.
get a piece of wood that goes the length of the cut, cover it with wax paper, find a way to hold it up tight, duck tape is good, I used a jack to just put pressure, put some pb in the cut then cover it with 1708, I did 4 layers way over kill but I will take the added assurance of nothing to worry about.
I really under estimated how much resin I would need, mostly because of the amount of PB I had to make. I got 10 gallons and I have gone through 7 gallons and all I have glassed in was my transom and made some hull repairs. Just so you have an idea.
