another new guy with a problem
20PRIVATEER
:facepalm:
I'd first like to say, Hi to all and I'm glad to be aboard.
I recently purchased a used 24v trolling motor. I picked up two new and matching 12v battiers and wired them in series with a jumper going from + on one and - on the other.
The first da that I used the motor it only lasted for a short time before it ran out of juice. So...I went home and charged the first batt. over nite. The next afternoon it had a full charge so I went to switch out...but when I hooked up the second batt. it already had a full charge. so...I hooked the batteries in series and checked them with a volt meter and they read 24v. so I assume my jumper wire is fine.
We went fishing this morning and the same happened again but with the opposite batt.
This time I had a volt meter with me and did a check. One batt. was stone dead and the other still read 13v.
so...I switched them around and keep fishing until a storm ran us to the hill.
What could be causing this?:confused:
Thanks for the help.
Joe
spdracr39
Re: another new guy with a problem
Positive from trolling motor to positive on battery 1
Negative from battery 1 to positive on battery 2
Negative from battery 2 to negative on trolling motor
Not sure how you could keep fishing if one battery was dead and they were hooked correctly because you would still only have 13 volts no matter which way they were hooked up and motor would run slow.
I think you should have both batteries load tested because even new batteries are bad under load sometimes.
20PRIVATEER
I unhooked the dead batt. and went straight to the good one.
after a little more looking, I think my problem is a bad batt.
more to come tomorrow.
Boatist
Any time you use the trolling motor charge both batteries fully with a good fully automatic or smart charger.
Checking the battery with a volt meter and no load will not tell you if the battery is fully charged or not.
5150abf
spdracr, that may be right but doesn't hooking a negative terminal to a positive terminal make fire????
Agian I am not an electrician by anymeans but I don't think I would ever do that, is that right?
Silvertip
Honorary Supreme Mariner
No it doesn't. Think about a flashlight. When you put two, three, four or five batteries in a flashlight they are inserted in SERIES which means the Pos of one battery is in contact with the neg of the one above it. Even your boat batteries are built that way. A 12 volt battery has six cells, each of which is about 2.1 volts. 2.1 x 6 = 12.6 (at least it did where I went to school).
Here is a diagram of a proper 24 volt troller system.
5150abf
Well there you go, I am a novice electrical guy and learned long ago not to hook + and- together, something with a battery switch, - on one side and + on the other.... but seeing the diagram it makes sense, never played with 24 volts before.
20PRIVATEER
one of my new batt. was a bad cell.
thanks for the replies
sw33ttooth
thats how my dad connects his duo camper batteries we talkd to camper place electricion he said either a jumper from positive to negative and you run off both or from negative to negative and run a shut off on positives to switch between the 2. either way it doesn't matter.
glad to see it was a simple fix
Silvertip
If you were to use a piece of wire and touch the POS of one of the battereis to the NEG of the SAME battery, yes you get sparks because you created a dead short. The same happens if you touch the Positive of the battery on the right to the negative of the battery on the left because you now created a 24 volt short rather than a 12 volt short. You also create a 12 volt short if you touch the positive of the battery on the right to the negative of the batter on the right. Simply adding cells or batteries in series does not make a short.
