Re: Another floor/stringer question to add to the mix
alright, i'm narrowing down to the final stage.<br /><br />here are my final questions:<br /><br />i am trying to save money, but i really want to go woodless. i want to try the hat stringer idea.<br /><br />i am thinking of getting enough 12"-wide mat tape to do two layers (and have plenty extra), and enough 18oz roving to do only one layer.<br /><br />here are my basic steps:<br />1. remove the top part of each stringer, remove the wood, leaving the fiberglass sides of the stringers intact. <br /><br />2. the sides will remain part of the structure, taking away the need to add two layers of roving. does that sound ok?<br /><br />3. using the existing roving as the base layer, i will add a layer of fiberglass mat tape along the entire stringer<br /><br />4. add a layer of roving to the entire stringer<br /><br />5. add another layer of mat tape<br /><br />6. add a final strip of mat tape along the top part.<br /><br />all in all, i will have 4 layers all around..<br /> -on the sides, i will have the original roving, plus a layer of mat, plus a new layer of roving, plus a layer of mat<br /> -on the top, a layer of mat, a new layer of roving, and two layers of mat<br /><br />of course, extra mat will be added to raise the height of the stringers to the correct level if one is lower than another, and for the final bonding with the new floor.<br /><br />does this sound ok, guys? if i don't have to do that 4th layer of roving, then i will save an extra 2 gallons of poly resin and an extra 20 yd's of 50" wide roving (a savings of about $100).<br /><br />thinking about it, if i have plenty of extra, the smartest thing would be to add fiberglass to the sides of the stringers, not to the top. does that sound right?<br /><br />thanks for all the odd questions, as i know hat stringers aren't typically done on this board. i wanna be one of the first few to do a good job at a hat stringer setup, so i can be used as an example (hopefully a good one, haha) for future jobs. i also wanna do a good job for me (no crap!). it's comin down to the time!
