Frank Acampora
Thread starter- Joined
- Jan 19, 2007
- 12,004
For those of you who read my last post on using the wrong plugs, I was looking for some parts down in the garage and came across this: Here we have a classic example of detonation damage due to a lean running cylinder. Note how much more severe it is than the simple melting of a hole from using the wrong plug.
Although severe, the damage is confined to the hot exhaust side of the piston, melting the piston and ring lands and breaking the rings. Also note that the piston crown is not damaged except for the broken rings banging against it, and the cool bypass side is almost untouched.
Mess with your carbs without knowing what you are doing, set them too lean, and this is what you can expect. Way better to run a bit too rich, smoke a bit more, and replace fouled plugs often rather than replacing pistons.
