anchoring a small boat
russelln114
Hello guys. I was wondering if anyone can tell me the type of anchor i should be using for my boat. I have a 12ft grumman aluminum lightweight. It's classified as a rowboat. This boat is very sturdy. I have 2 mushroom anchors. The type of water i fish in is a resivor with a muddy bottom. Last night with 10mph winds my boat was moving all around. I may not be setting the anchor right. When i pull up to a spot where i want to anchor i just drop the anchor straight down off the bow then tie off the excess then i do the same for the back of the boat. Should i be letting slack in the line or am i not using the right anchor?
Re: anchoring a small boat
Mushroom anchors, in my experience, aren't great with that type of bottom. I've had the same issues while fishing. I recently replaced mine with a danforth and it's much better. However, in addition to the type of anchor, you'll get better results with a 6 or 8 ft. length of heavy chain between the anchor and anchor line. Also, allow for enough extra line so that it's coming up at an angle. Where I boat I usually use about triple the depth and it works ok.
FunInDuhSun
Mushroom anchors aren't the best for mud but it it's big enough it'll work in calm conditions. Might be better to get a samll Danforth or Delta, and add a piece of chain to it.
The REAL key is having the proper scope in the anchor line. Under normal conditions you want 7 times the depth of the water + the height of the bow.
As an example, lets say you're anchoring in 6 foot depth. You need to add the height of the boat from waterline to bow, let's say 2 feet. Soooo, we have a total height 'straight down' as 8 feet, so you'll need to deploy 56 feet of anchor line to achieve 7:1 scope. In heavy wind or current the scope needs to be lengthened to 10:1 or even more.
Not convinced? Read this:
Here are some basic anchoring guidelines:
Anchors are designed for specific bottom characteristics. Make sure that you buy an anchor designed for the type of bottom primarily encountered in your boating area. Even with a small boat, five or six feet of coated chain is desirable. Shackle the chain to the anchor. Put a thimble on the end of the anchor line and shackle that to the other end of the chain. Chose your anchor line carefully. A line that is too heavy will actually cause problems because you?ll loose the "elasticity" that absorbs the shock and keeps the anchor well set.
Pick your anchorage carefully. If there are other boats nearby, you will need to "guess" at their potential swing. A boat on a mooring will have very little swing but a Yacht at anchor may have considerable "scope" out and may swing widely. A shallow draft boat will be more affected, usually, by the wind whereas a deep draft boat will be more affected by the current.
Put your bow into the wind or current (whichever is having the greatest affect on your boat, power up slowly to or just beyond where you want your anchor to lie and check your forward motion with your reverse gear. Double check to ensure that the bitter end of your anchor line is attached to something sturdy on the boat. Most experienced boaters have watched at least one anchor with a few hundred feet on line disappear over the bow because they forgot to secure the end.
Don?t throw the anchor ? it will probably get tangled. Release it by holding on to the chain or line, making sure that the chain and line are free, and dropping the anchor off the bow. If your anchor line was properly coiled, it will "pay-out" smoothly.
Once you see slack in the line, feed out the proper amount of scope as the boat drifts back. Hopefully, you?ve got your anchor line marked at 25? increments. Average "recommended" scope is somewhere around 7 to 1 or 8 to 1 ? that means that if you are in 20 feet of water you will want to pay-out between 140? and 160? of line. You also want to take into consideration the distance between the water line and the bow cleat and also any depth increase because of tides. If the tide may come in another 4 feet and your bow cleat is 3 feet above the water, you are, effectively, in 27 feet of water and would need to pay out around 200? of line. Up to 15 to 1 scope may be necessary in strong winds or currents.
Once the scope is out, secure the line (cleat and chock) and "back down" on the anchor keeping your bow into the wind/current. Idle speed is usually sufficient to make the anchor "bite" into the bottom and "set."
Put the engine in neutral and get your "bearings." Find two points on each beam that form a natural "range" or line and a third either ahead or astern from which you may be able to judge distance. They can be other anchored boats, rocks, buoys or points on land. Sit there for a few minutes to make sure that none of the angles or distances to these points change. Any change would indicate that you are dragging and need to reset your anchor or pay out more scope ? or both.
Now do whatever had planned to do when you decided to anchor and have fun doing it.
rbh
Nothing is really good in a muddy/silty bottom.
Our danforth doesn't bite worth a darn, I would suggest you try a plow (fortress) style with a little 20 foot +- section of chain.
kg5388
what size mushroom anchors? how deep is the water?
I use 2 semi truck rotors they are a little over foot in diameter and weigh 20 lbs and I anchor like you describe in 4 to 20 feet with no problem in my 14ft jonboat.
RicMic
Your main problem is not enough rope. I use a river anchor, which just a mushroom anchor with cutouts and a mushroom anchor on the stern in my 14' jonboat and they hold just fine, even in some very high winds. The lake that I use it on the most is all muddy or silty bottom, the trick is to let out enough rope so that the anchor is being pulled from the side. Using a few feet on chain on the anchor helps do the same thing, lay the anchor over on it side, so that its digging in, instead of sliding on its round bottom. I use Danforth anchors as well, but if there are trees or logs on the bottom the danforth will hook on them and you won't get it out.
kg5388
I use 2 semi truck rotors they are a little over foot in diameter and weigh 20 lbs and I anchor like you describe in 4 to 20 feet with no problem in my 14ft jonboat. I just put the bow into the wind a use a little more line off the bow for deeper water.
