Am I missing a part here?
series60
Lots of water comes out of this hole while running on muffs or while in a barrel with no muffs. I don't see any cracks in the new water pump housing or any other obvious issues. Am I missing a part or some kind of plug here?
lowerunithole.jpglowerunithole1.jpg​
Re: Am I missing a part here?
Ayuh,.... Best I can tell, yer pictures are of the exhaust cavity drains...
That whole area inside the drive upper/ lower is a Wet cavity...
It's gotta be able to drain...
series60
Yeh Bond-o it looks like the entire cavity is wet. This is the first time since the complete rebuild that I have had all the pieces installed and running so I am very unsure about how much water and where it should exit under idle on the muffs. Most of the water comes out the relief ports at idle. I had another question regarding the similar issue here.
Ayuh,... Looks like the Same, not similar to me....
