Re: Aluminum Adhesive
I plan on doing the same thing installing transducers to the toons. I bought 3M 5200 adhisive/ sealer, which is for under water use, and I also got 3M double sided tape and the tape is for outdoor use and will hold 10 lb for every inch of tape. I cut 5" pieces of allunimun and installed the transducer bracket to that. I plan on putting the tape on the back side of the bracket, then attach it to a good clean section of the toon, then seal around the edeges of the bracket with the sealer, then hold it tight with duct tape untill it drys for a few days. if all that fails next step will be, have a bracket welded. my pontoons dont have any brackets for mounting.
Jack
