Alternator spinning, but no other power to engine?
sportsguy3223
I have been able to fire up my 1989 Evinrude VRO twice this year, no problem. However there are a few times where when I turn the ignition, all that happens is the alternator starts spinning, but that's it. No chugging, no semi-revving, just the alternator. Trim on the throttle stopped working as well. Battery is fully charged.
Does this sound like an ignition problem or a starter? If it is wiring, do you know where I might start at? It's weird, either fires up perfectly, or does not seem to be getting any power at all.
Any ideas would be appreciated!
NYBo
Re: Alternator spinning, but no other power to engine?
Welcome to iboats!:cool:
It sounds like the Bendix gear on the starter isn't engaging the flywheel. The alternator, if so equipped, only spins when the motor spins.
