Altenators, Mando and Delco
Chevysolid
Ok,
I want to replace my Mercuiser 5.7L Altenator part number 817119-2 (Mando) with a higher output altenator.
1. What is the difference between Mando "style" and Delco
2. What Delco part number does this interchange with?
I am looking at altenators that show Merc (delco) part numbers 78403A2, 78477, 92497A3,
would these be direct replacement.
They are both three wire set ups and I only use the three wires (I see on the mado they have two other terminals, stator and something else)
Thanks
Re: Altenators, Mando and Delco
Ok,
Ayuh,... Why,..?? Are you having Battery issues or something,..??
It's hard to believe you're pulling loads bigger than the stock unit can provide,...
I usually replace with what I found,...
Swapping usually means the bracketry is different,+ God only knows how far back you've gotta change things to realign the belts or something....
I can't tell you the differences in those part #s,..
You've been prusing the parts listings,.. Do they look alike,..?? Are the bracketry part #s different,..??
Chevysolid
To answer my own question in case others have similar, YES they the delco did interchange without any issues.
