Alt Gauge Help
sin1000
I bought a 2005 Chaparral w/ a Volvo Penta 5.0 GL-E, the block cracked replaced it with a Volvo Penta Vortex 5.7, I go everything else working but ALT Gauge I received wiring diagram with new moto (pic enclosed), issue I a am having is on back of alternator there is a connector I am sure powers the gauge but the wiring diagram I do not see where to attach it to maybe crossed eyed at this point just missing it but pics are attached Thank You for your help, also the gauges have like pin connectors connecting them not like screws
sin1000
After looking at wiring diagram looking at Purple Wire #5 possibly it can tie into it?
alldodge
The voltmeter does connect to the purple wire but it would connect to it at the helm, not at the motor.
Each gauge will be daisy chained to the purple coming from the key switch
08Chap180
I bought a 2008 Chaparral 180 ssi in April of this year and the voltmeter didn’t work on it. After checking all the wiring I had power to gauge on the purple wire, the blue wire is for the lights, and mine has a yellow for the ground. All that wiring was good so I bought a new Faria gauge, exactly like stock off of eBay. That one didn’t work either so I called Faria and they told me I have 2 bad gauges (original one in the boat and the one I bought). They could fix them for around $90 each. I decided to have a custom made digital gauge made by AutoMeter, it’s not an exact match but it’s very close. If it didn’t say AutoMeter on it you wouldn’t know it wasn’t stock.
I posted all that to say maybe you have a bad gauge, if it’s a Faria gauge like mine, apparently they have had a few issues with the voltmeter gauge over the years.
sin1000
My biggest problem is I do not think I hooked up alt correctly I had a brown/black wire coming from old harness that also went to the risers and then went to back of motor it was connected to the P connector on the alt I am trying to find out where that connected or maybe need to look alt again
sin1000
Maybe I am getting to caught up in the color of the wires I do not have a Green nor Orange wire coming off the alt. I now have a 5.7 Votex motor in the boat now so maybe I need to run a Purple wire to the electric choke and need a ground of course
alldodge
Maybe you don't have a GL-E
Don't know, but the wire hanging in the other pic looks like the water temp if its Tan
sin1000
Maybe you're right that tan wire is water temp wire I need to ground the alt to the frame and try and take 4 cluster gauge a part to see if wire is loose
