alpha1gen2 leaks
juneau712
over the winter i saw my drive was leaking through my outdrive hub had my mechanic look at it and he supposedly replaced every seal in the lower unit i put it in the water and it still leaked .had it taken out and put in still has same problem any one have any idea's
thanks
Re: alpha1gen2 leaks
Your Mechanic was Trying to save you some Money,+ Didn't replace the Shafts that're scored,........??.....
And now the New Seals are Old Seals,......??...........
I Donno,...... Your Mechanic would be the 1st person to Ask,........
Is it leaking in the Same Place,..??....
