Alpha one trim won't raise completly up
Jerry Shackelford
At the end of the day on the river, as we were heading back to dock, I noticed that the trim adjustment on the throttle was not raising the trim up very far. I went back to the trailer switch just to check if everything worked there and the trim was able to be adjusted through the complete range of travel. What gives? Where do I start to check? I have looked at the position sensors and they appear to be intact, not damaged or moved. The out drive will travel through it's complete range using the trailer switch but only a few inches using the trim adjustment or the throttle? Thanks
