Alpha One (MR) water pump over torqued
ErieRon
I just replaced my complete water pump (plastic style) on my Alpha One drive. Unfortunately I had a huge brain-fart and over torqued the three nuts by 2-2-/12 times (200 lb. in. instead of 90 lb. in.). Can anyone tell me if I need to replace the upper housing, or will loosening and re-torquing the nuts be adequate?
Thanks in advance.
Ron
JustJason
Re: Alpha One (MR) water pump over torqued
take it apart and look at it, including the lower part of the pump as well. If you cracked it you need a new one, if you didn't crack it your all set.
ErieRon
JustJason: Thanks for the prompt reply. I'll do just that.
Regards,
Ron
