Alpha one Gen 2 outdrive
90stingray
Re: Alpha one Gen 2 outdrive
Yes, if you just changed the lower half of the drive and have the same prop... all should be the same. Gear ratio is in the upper half. Not sure what went wrong or why the rpms running sky high... but something is wrong.
Jamz3333
ok thanks for the info. Do you have any idea where i need to start looking for the problem?
ralphy670
ok i understand. well where do i find the ratio for the lower drive and what steps do i need to take to get it back to normal? It currently has a 4 blade 20 pitch prop right now. My bro who has the same outdrive and has a 4 blade 22 pitch that im gonna try. It was also on here where i was told the ratio didnt matter with the lower drive.
Sorry, my bad. I read your post wrong. I thought you changed the whole drive. But now that I read it again I see you changed the lower only and therefor it does not affect the ratio.:redface:
Jamz3333
haha its ok dont worry about it.
Jamz3333
does anyone have any advice at where I could start looking for the problem? I didn't change anything besides the lower drive. :confused:
