Alpha one drive
roffey
I have a 3.7 (488r) merc currently in my boat. If I were to replace the motor could I replace it with a 4.3 or would I have to change a bunch of parts in the out drive?
Slip Away
Re: Alpha one drive
Buying a newer, used boat may be cheaper than trying to make a switch of engine/drive.
thumpar
Re: Alpha one drive
The outdrive would not need to be changed. I am not sure about the transom assembly. The engine mounts will be you hardest part. I agree with Slip Away, sell it and buy the boat you want. It will be much much cheaper and easier in the long run.
Re: Alpha one drive
Ayuh,.... Agreed,.... Any fitment issues will be inside the transom,.....
A 4.3l will run with the 470's gear ratio, No problem,....
The right Y-pipe might be a bugger, or not,...
