shekinah5678
Thread starter- Joined
- Mar 25, 2007
- 41
Hello all.
I am new to creating posts but have been reading the forum for years.
First of all I have a 1992 Crownline with the 4.3 LX mercrusier and Alpha one drive. I've had the boat for about 6 years now. I just went out and started her after a long winter and all was well until I tried to put it in gear. When I shifted it into forward gear it grinded very loudly and the grinding didn't go away until the RPMs increased significantly. I?m not sure if they went away then or the engine noise drowned it out. I did this all in the drive way with the ear muffs on so I have no idea if the boat would actually move or not. I did take notice that the propeller was moving. I tried shifting it to neutral and back to forward with no change in the grinding noise. I also turned the motor off and checked the prop seemed to turn fine in neutral and caught and held strong in gear. I did notice a slight movement of the prop shaft forward and back only maybe an eighth of an inch. I think that play has always been there. I Didn't let it grind long maybe 30 seconds so I?m hoping I haven?t caused any further damage. When I shifted into Reverse it worked fine no grinding except the usual quick clunk sound. I have read other posts that indicated either a faulty or out of adjustment lower shift cable. None of the posts that I could find had my problem of continuing to grind until shifting back to neutral. Are there any other more likely explanations? I would note that the boat shifted just fine when taken out of the water last fall. Could the shift cable do this over the winter without any use? How would I go about adjusting it? Is that something a novice mechanic such as myself could do? Any and all input would be very helpful.
Thanks Very Much
Thanks Very Much
