Alpha lower with pre-load pin...
Status
Not open for further replies.
No Worries
Is this possible? I did the impeller kit today and it was odd that the impeller base didn't fit. Sierra #18-3320. The shaft has the pre-load pin on it but the lower half is visually an alpha.
No Worries
You probably have a MR drive..........
I thought an MR was an alpha. Do you mean an R?
An R lower with an alpha upper? Is that possible?
The upper is definitely alpha. Thanks.
Ayuh,.... Unit for unit, uppers, 'n lowers can be shuffled like cards, mix, 'n match 'bout anyway ya want,....
MC-1 upper or lower will work perfectly with a R, or MR, or Alpha 1,...
Both forwards, 'n backwards compatible, right up to '91, 'n the Gen.II drives, which don't interchange with any of the previous Alpha series,...
No Worries
No Title
I have an '84 SeaRay Seville and have been told it's still considered a "pin drive". It looks just like an alpha but the impeller base from the alpha one gen one kit I bought didn't fit.
Ayuh,..... Must be an R, or MR,.....
There's 2 other water pump kits, the one without the water port(which I think is what you want),....
'n the one with the water port, which is for much older MC-1s,...
Bt Doctur
that number comes back as MR/Alpha1 drive ,used in drives without the preload pin
should have been 18-3317 no flushing port
achris
More fish than mountain goat
R, MR and Alpha One all use the same upper. No difference externally or internally...
If the lower has a pre-load pin it's an MC-1 or an R. MR and Alpha One (identical internally and externally) have NO preload pin.
As far as the housings go, for the outside, R, MR and Alpha One look pretty much identical. It's very possible the original lower was damaged and someone replaced it with an R...
Chris......
shughes12
Long shot on an old thread. I got a replacement drive that has the pin but my old leg doesn't have it, can I still use it?
Status
