TampaBoater
Thread starter- Joined
- Feb 23, 2012
- 207
So, to recap, I had replaced the bell housing gasket and then reverse wouldnt engage. Pulled the lower unit, and reinstalled making sure the prop was locked on fwd all the time. Nothing. Still no reverse. Pulled the entire drive, inspected the shift shaft, and the small, black pastic piece on it that engages with the cable fot the shifting operation, all is good, reinstalled drive, with the shift in fwd, and propeller locked in fwd, small turn to the prop to align the splines, everything goes in smooth as butter, tightened everything down, connected the trim cylinders. Again, nothing. I don't know what else to do. The shift cable when engaged manually, feels smooth and free, but still won't engage reverse. All it does is ratchet but clutch will not engage. Fwd is fine...kicks in nice and smooth. (at least I got fwd if I wanted to go out for a trip around the intercoastal) Any suggestions?
