Alpha 1 leaking oil
sillydilly
Wondering why my leg is leaking quite a bit of oil from the water intake..?
for what it's worth my air intake is cracked and my engine took on a bit of water and I drained it into that drain pan. then I noticed oil coming out of my leg...?
Ayuh,.... There are seals in the drive, you've got atleast one, leakin',....
Probably the shift shaft, but a pressure test will tell ya which one,.....
sillydilly
what's the best way to get a fitting to
pressure test it ? I wanna go off the top drain plug ...
Ayuh,.... The drain, 'n vent are 3/8" - 16,.....
I use the end off a drive oil fill pump,....
The drive has to be drained 1st,....
If ya split the upper, 'n lower, a cork or rubber stopper can be used to plug the oil passage 'tween 'em,.....
