alpha 1 gen2 pinion gear installation.
oops!
hi all.....i am installing the gears in my lower unit.
i am having a real problem getting the pinion gear to seat......is there any tricks to this....i have read the manual 3 times and seloc just says it will slide in. ?
it is getting caught on the casing, and between the shift dogs on the prop shaft.
thanks
oops
Bt Doctur
Re: alpha 1 gen2 pinion gear installation.
It does just slip in there , a little wiggle too.sometimes you can gently push the prop shaft down a tad.
Pete104
I can't believe people purchase "seloc", with all the bad press it gets from everywhere.
