alpha 1 gen 2 pump kit #
fat fanny
Would the proper proper kit # be 817257-5 for my 96 Alpha 1 gen2 serial #of530668 ?
MarkSee
Re: alpha 1 gen 2 pump kit #
If you want to go OEM then the full water pump kit with housing and all the parts, including 1-piece faceplate/gasket is 817275Q05
Mark
fat fanny
I thought that was correct I know the Q stands for the pretty much nothing! Thanx
Fun Times
Or if you're impeller housing & carrier assembly are still in good condition, then water pump kit 47- 43026Q06 will save you some money.
Q stands for Quicksilver, a Mercury registered trademark.
fat fanny
Does 47-43026Q06 include the water tube ? You know this info and many other part#'s would be a good info point in the stickies!
MarkSee
As Don's list shows even the 817275q05 rebuild kit does not include the water tube, guide sleeve or coupling but it does include the 2 o-rings that go inside the coupler. They must consider that outside the scope of a water pump rebuild.
But on the + side you do get the quad ring that goes between the 2 halves and a drain plug fiber washer........
Unless you've already taken the existing water pump apart and know for sure you don't need a new pump housing or carrier assembly, the Q05 kit is the way to go if you're trying to buy parts ahead of time. And you get the 1-piece gasket/faceplate that makes installation a breeze.
Mark
fat fanny
My pump is disassembled and the housing and wear plate have no signs of wear at all if kit47-89984TS is applicable that's what I need but being it states for serial #'s OD and below and my drive is in the OF range it's ?ionable! any insight and by the way thanx Don!
Don S
A,B, and C are below D, F is considered above the letter D.
You want the impeller kit 47-43026K06 for a Gen II drive. The plate is just an extra, you need the rest of the gaskets.
The 47-89984TS kit you posted is for the Alpha I (Before Gen II) drives. Didn't you notice that parts in the picture looked different?
fat fanny
Yea after a second look. I must not of worded that right with the letter order. I will have buy the water tube separate. Once again thanx Don.
