Alpha 1 Gen 2 outdrive upper lower seals
scbackpacker
Ok I have the upper portion of my outdrive apart and the 2 seals are out, The new Quick silver seal kit 26-88397 1 has only 1 seal. Seal is same diameter but a little thicker than a single seal but not as thick as both seal together. Is this a new seal design or have I got the wrong kit? If I need to get 2 seals the bottom seal goes with spring down correct? How about the position of the top seal..spring down or up?
scbackpacker
Thanks for the reply and service manual. I went ahead and ordered 2 seals to be sure I get it right.
achris
More fish than mountain goat
I have seen the new ' double seal'. Just put that in place of the 2 single seals.
