Clarko1988
- Apr 27, 2021
- 103
I have oil leaking from prop. What and where do i reseal the lower unit tried finding videos and have not found any?
LEAST likely!It might be your prop shaft seals (most likely)
That's just the lip of the water seal. The oil seal behind it is probably not where your oil leak is coming from.I think you will agree this seal was BAD.
Seal. There's only the one. Use the special tool and remove the shift shaft bushing, and replace the complete bushing (it comes with the seal in it).Soo i found the leak and was coming from the shift seals.
