Alpha 1 flappers
prlwng
Knew I had a headache. After first spin on river.
Anyway replacing cracked head, was new when purchased, there are no flappers.
Are all gen 1 flappers the same.?
Could not even find any pieces in ypipe.
GA_Boater
Welcome aboard.
What in 'ell are you working on?
What's left of the shutters are on in the lower unit or in the exhaust passage somewhere. That's where they end up.
prlwng
Have 90 crestliner, 4.3 alpha1.
In current tear down found no flappers or pieces of them.
to get new ones will I need a part number or are they all the same?
Thanks all.
GA_Boater
Don't start a new thread to answer a question. You won't get any help that way. Both threads have been combined.
Got a serial number for the motor and outdrive? 3 or 4 inch exhaust?
prlwng
Sorry but it never showed for awhile so tried to repost .
will try to get numbers tomorrow.
How do I measure for inches of exhaust.
Finding many things done wrong on this boat. Gonna be an expensive learning project for me. But it sure is nice to relax in waiting for the cats to hit.
It is not perfect in carpet and such. But then heck fish will be on floor anyway. Room to stretch out and take a nap also.
GA_Boater
The Y tube.
But a serial number is best to chase parts.
sogood
I replaced the flappers on my 5.7 mercruiser as part of a resto and as stated, any remnants of the old flappers, should be at the bottom of the Y pipe or down in the lower drive. Changing them on my boat was easy enough, with room to work. Having said that, I remember reading somewhere that to change them, the engine must be removed!! Not so in my case. Sizes do vary in relation to the size of the Y pipe. Sorry, can't help you with the details
prlwng
See now this will take a new style flapper. Each side. I am sure I boats will send me right ones when I make the purchases. Already got a list going for many parts.
Had to reread the stickies to more understand what I getting into.
oh, thanks to a coat hanger, smashed end and tiny rake on end found they are the one piece with rod thru them.
Goldie627
im not recommending you purchase from these guys but they do make finding part numbers easy, mercruiserparts.com very intuitive
