fishnfool101380
Thread starter- Joined
- Jun 7, 2015
- 32
I will be painting with Rustoleum marine top side paint and Valspar hardener over gelcoat. Paint will be sprayed on.
I am looking for advice.
1. What grit sandpaper before primer (wet or dry sand) ?
2. What grit sandpaper after primer (wet or dry sand) ?
3.What grit sandpaper after 1st coat of paint (wet or dry sand) ?
4. What grit sandpaper after 2nd coat of paint (wet or dry sand) ?
5.What grit sandpaper after 3rd coat / final coat of paint (wet or dry sand) ?
6. Paint / hardener mixing ratio?
7. mineral spirits or acetone to thin, or a mixture of the two and how many ounces per quart?
After proper cure time I will be buffing the paint job
