MercMonster
Thread starter- Joined
- Jun 3, 2007
- 151
Having problems with aligning the drive. The tool shows even marks all around but seems to "bottom out" way short of where I figured it would. Should the tool at least go to the first depth gauge on the tool? The grease is where it is in the picture because that's as far as the tool goes in. I had the whole first depth mark greased before thinking it would bottom out there. But this is all of the tool I can get into the splines. Also tried adjusting the height of the engine and moving the gimbal bearing around w/ the tool - 4 hours. (this is the same drive with the same coupler, but different engine)
