Aligenment ??
Don S
Re: Aligenment ??
Put a mark on the front pulley of the engine and bump the starter. Yes, you have to put it in neutral, there is a neutral safety switch to keep you from starting in gear.<br />Since you are only going to be just barely bummping the key to get a quarter or half turn, I doubt it will start on ya. But it wouldn't hurt to pull the coil wire out of the distributor cap and ground it.
mike456
Re: Aligenment ??
Final update. Fine tuned the alignement, tightened down the motor mounts and checked it at 90, 180 and 270. ALL SEEMS WELL!! Plan to finsh my bellow replacement in the next few days and go boating this weekend. YAHOO!!!<br />Thanks again for all the help, I never could have done it without you guys.
