alarm
jwr44
any help. have 200 mariner alarm went off a quick beep.replaced oil res cap, oil sensor module,checked oil pump for output. does not seem to be oil issue. if i dissconect tan wire from module to post where it meets heat sensor wire the alarm stops ringing. i have good water flow replaced thermostatsmy sercvice guy who is also friend says it is possible module is bad any advise
Laddies
Banned
Re: alarm
The tan wire to the heat sensor don't go through the oil module, if you have a steady horn and it goes off when the heat sensor is disconnected you have a bad heat sensor
