Alarm on start up
Daarrell Benedict
When I turn the key on and start the motor an alarm sounds in the control and won't go off. What is it for. 1979 16' Lund deep V.
tashasdaddy
Re: Alarm on start up
which alarm? J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
Daarrell Benedict
It is a constant alarm at the key. It is on at cold start up and on warm start up and never goes off.
bychancex
Caution: I'm a complete novice!
I've actually had a faulty alarm (a short or something) and had to replace it. So if it's constant on a cold start, it could be a bad alarm.
Daarrell Benedict
Found the problem. The case touches the terminal when tightened down. Bent tab and now all is fine. Thanks everyone.
