Alarm - Johnson
beginner22
I had oil and gas leaking from the VRO Pump. I replaced it and took it out on the water. I turned off the motor to do some fishing. When I went to start it up it would not turn over. I took off the cover and revved it up with my hand while my friend turned it over. When I got back to the marina I noticed oil/gas leaking from the carb cover. What could this be? Also on my way in the alarm sounded. 1st it was a beep every 20-30 seconds and then eventually it was beeping every 2 seconds. Was I not getting oil or was I overheating? Like I said...I just changed the VRO pump and as far as I know my temp gauge works. Thank you for your help.
