AeroCraft York 1960ish Transom, Stringers, Deck
saginawbayboater
Re: AeroCraft York 1960ish Transom, Stringers, Deck
today I started a layer of CSM on the tops of the stringers.
Got about half done, so nearly ready for decking!!! :whoo::flame::single_eye:
OK not sure what the single eye is, but it's cool!!
saginawbayboater
Good stuff going on there sbb!
Don,t ya just hate it when your scissors get all gunked up with resin and fuzz ! :facepalm::D
Keep up the good work ! You"ll have a dance floor before ya know it ...
Thanks SP hope to be dancing soon!!! Went back through your thread, Lots of good stuff!! How is the tree doing? :joyous:
saginawbayboater
Got some freight today, 15 yards 1.5oz CSM. Cut out a full transom layer of CSM and 1708 to finish it off. Then the rain clouds came in, so maybe tomorrow we can wrap that up. :facepalm:
Happy 4th Y'all :watermelon::drunk::drunk:
Woodonglass
SBB,
Right Back Atcha!!!! You're glassin skills are exceptional!!!
saginawbayboater
This morning I put down a layer of CSM.
really happy with how it went down.:joyous:
saginawbayboater
this afternoon the final 1708 went on and I could not be happier. it went on very good!!!:love-struck:
jbcurt00
Looks great SBB.
Trooper82
Looking good sbb....happy 4 th!
Woodonglass
Well, I'd say you could give instructions on how to lay glass!!!! I've not seen to many transoms that are any better than the glass work on yours. Very nice!!!
GT1000000
Outstanding glass work...A#1!
sphelps
Tree is doing great ! Plenty of new growth .. I really needed a good shade tree in that part of the yard . The morning to noon sun really heats up the kitchen . Glad I saved it from the dumpster !
BTW , You have flat gotten the hang of this glassing thing . Keep up the great work ! :high5:
saginawbayboater
Thanks everyone for all the kind words!! It is very encouraging!!:joyous::joyous::joyous:
Woodonglass
Momma always said..."Sometimes the Truth Hurts...But...Sometimes it Don't!!!!:eek:
saginawbayboater
I have a question, if a put a bead of PL on top of the stingers while installing the deck should I still wait three days before PBing the edges of the decking?
Thanks for input!
jbcurt00
No need to wait to fillet the deck to hull, BUT you'll want to screw the deck down to the stringers really well. Or plan to leave the deck weights in place for 72+hrs. Under the deck the PL on top of the stringers won't be exposed to much (if any) airflow. So 72hrs would be my MINIMUM wait time, more would be better.
That's the reason I have stopped recommending PL as an good alternative to PB, too much time waiting for it to cure. If asked, I will say it's an alternative, but PB is a much better choice for many reasons.
saginawbayboater
I will be screwing the deck down, but I want to be clear that the PB fillets won't be bothered by the gassing off of the PL on the stringer to deck joints?
jbcurt00
Is below deck 100% sealed once you PB that joint? If there's openings for water to flow back to an open bilge, then below decks will have airflow, very little, but airflow. If it's 100% sealed, foam &/or no openings to the bilge, there won't be any airflow. 100% sealed may delay even further the PL cure.
The PB shouldn't delam from the off-gassing if the bilge isn't sealed. Directly in contact w/ uncured PL is generally what causes the off-gassing to adversely affect the poly resin/PB. But if it's 100% sealed, it may delay the PL cure.
saginawbayboater
Thanks a bundle JB!! I think the direct contact between PL and PB causes issues, but I wasn't sure, I think I'll be good.
