Hello, I am a new poster to iboats, but have been following for quite some time, and have used the search function a lot for past problems.
After spending pretty much the entire day searching and researching different methods, I am confused at what my next step should be, and requesting info for the easiest/cheapest route that still gets good results.
I tore out all the rotted carpet from the rear and front decks and gunwales of my 18' center console boat (2000 VIP Baystealth). After hours of scraping and sanding, I finally got all the glue off and down to the fiberglass. I then was able to fill the bigger dibets/chunks that were in the fiberglass. I discovered that boat manufactures are able to skip smoothing and leveling surfaces when it is going to be carpeted, but now that I am wanting to paint I need a smooth level surface free of all the tiny or shallow pitted areas showing in the top layer of fiberglass.
I am hoping to go about this without adding more cloth or mat.
I originally thought that just my primer (Pettit Easypoxy white undercoater) would hide most of it, but after applying a quart I realized it wasn't going to work and I am probably skipping a step :facepalm:. Even some of the areas where matting is was still showing through.
So, will several coats of a high build primer such as Pettit Vivid Epoxy Marine Primer work for creating a smooth surface for a topside paint job in my situation (I will be using Pettit easypoxy single component polyurethane topside paint)? This would be the ideal route.
Or do I need a filler? If so, what would work for a reasonable price and a large area? I have seen a few brands/types mentioned but what specific kinds will work for such a large area? I assume I will need something with easy "spreadability" as well.
Another option I have seen tossed around is a polyester resin with chopped fiberglass and microbubbles. Any ideas on that? Will just polyester resin without the glass, layered up with a top layer with wax work?
Also, with any recommendations let me know if I will also have to sand off the existing paint that I applied.
Thanks in advance, and sorry about the long rookie question.
