Advice
Tomle91184
94 evinrude 115hp E115TLERC compression test 100, 105, 100, 60 (cold) because the water tube and lower unit not in place. I pulled the head off that lower piston was pitted on top and the rings are gone, little to no scoring on the cylinder walls I took a tooth pick to the scoreing and didn't get bound up. The upper piston looked good with good rings, with almost identical scoring or scratching, with same results with tooth pick. I'm pulling the power head anyway to replace the water tube, so I'll pull the other head off to check the other 2 piston just in case. Should I just replace the rings on the lower piston or should I hone the cylinder and replace the piston and rings?
Faztbullet
Pull it apart and mike the cylinders if any scoring doesn't clean up and if cyl mikes .3.503 or bigger it needs bored. I myself would bore all 4 .020 and rebuild it.
Honorary Supreme Mariner
This failure as you may know is very , very common !-----Replace all 4 pistons or you will be doing this job again.----Now you know why the motor was for sale !
Tomle91184
I took the risk for the boat if the motor was complete junk I will repower it
interalian
It would be tough to justify rebuilding the motor since you don't know if the lower unit is in good shape either. Re-power would make more sense. When I did my rebuild, I had a known good set of parts with low hours.
Tomle91184
If I re power it won't be until december, if I re build it could be for nothing or third option put back together run it till it's dead and go with first option
