Bustedknuckle84
- Sep 29, 2010
- 421
I have a tsunami 1200 gph pump currently installed. I bought the same pump and setting up the pump on another auto switch. Should I setup another hose output or will a two way into the current hose setup work? Under assumption they would operate at the same time. I believe the hose is a 3/4 inch or 1 inch not at home to check.
