Adding shore power
trainwrecker22
I would like to add shore power to my boat. I have trailered it for the past 2 years. It's not a big boat only a 24' er. But I am thinking about putting it in at a local yacht club. I would like to add shore power to run a battery charger, and maybe a carry on ac unit at times. I guess my question is can I just wire them direct or do I need a distribution/breaker panel?
You are into something that best be done by someone who understands marine shore power installations. The last thing you need is to electrocute someone. This is not a job for a novice.
R055
Yeah read an article on yahoo a couple days ago about a girl who was swimming and drowned, she was electrocuted in the water from her parents dock that didn't have GCI or any other protective measures.
Natesms
You'll need a breaker panel if you put in a shore power outlet.
For what it is worth. I actually had a 24' that had the shorepower plug on it and a carry on AC unit. I always had issues with getting proper power to the AC unit and just ran an extension cord from the dock to the AC unit.
thumpar
Another thing to add is to make sure your anodes are good. What engine/drive do you have?
JoLin
There's a lot to it. I did it on my boat last year to add a dedicated circuit for my new air conditioner install. Yes, you need a breaker panel, and you'll want 2 other breakers in addition to the main breaker. One for the AC and one for the charger. I strongly suggest you have a marine electrician do it. If you're determined to do it yourself, do a lot of reading and don't forget to put a galvanic isolator in the circuit. At the least, pay an electrician to sign off on your work.
My .02
Grub54891
Yup, as stated above, have an ABYC Certified electrician install a breaker panel with correctly rated breakers.
