adding flooring
gtodd
Does anyone know how to go about adding floor boards? Framing,etc.? Pictures would help.
gtodd
Re: adding flooring
the boat i'm thinking about adding floor boards to is a 2000 14' gregor h42
likalar
Re: adding flooring
Sorry I didn't see your post sooner. I added floor boards to my 14' Gregor. If you havn't already done the project, email me at EDIT (put Gregor boat in the subject line) and I can send you some pics. I used vinyl covered marine plywood and aluminum "L" strips attached with sheet metal screws to the factory metal seats. Came out looking factory installed, and they're plenty strong.
Larry
d-lutsky
Re: adding flooring
I just joined. have the same boat and added floor boards, send a note here if you still havent started your project.
gtodd
Re: adding flooring
Thanks d-lutsky. I've since gone a different route using 1/2" rubber matting inlaid between the two wide slats that run between the seats. I'm still interested knowing how you went about your install.
Anza
Re: adding flooring
I am just starting on rebuild of 14' Gregor and would very much like to know what you did and how.
Email is anzapac@yahoo.com
