Adding a Battery isolator
Rranger
Adding a Vervor battery isolator to a wiring setup with a perko switch. I'm not sure how to wire the battery isolator in. Not much on the net. Hopefully someone on here knows. Would appreciate hearing.attached is a crude drawing of present system and the vervor wiring diagram. Second question is will be addind a 110V 2 bank 10amp battery tender can I hook to both batteries as normal and will charge when perko switch is off or on?
alldodge
Your saying Isolator and sketch list VSR and pic shows a Relay but calls it a Voltage Sensing Isolator.
BTW - Vervor is a China company that sells lots of stuff, basically middle man
Rranger
Thanks All Dodge. Looks like I can run a separate positive wire with the Isolator in between battery 1 to 2.
dingbat
Make it easy on yourself and run the positive wire from battery 1 to battery 2 terminal on the on-off-both switch.
Surprised they are not specifying fuse when tying the 2 batteries together like that.
