AD31P Overheating
Flybrain
My AD31P was running at about 90 degrees.
I had the boat out of the water for a month to have the drive and engine serviced. Also had the heat exchanger cover cleaned and refitted as it had a small leak.
When I launched the boat a few weeks ago it overheated as soon as the engine was put under load.
The engineers thought it was a thermostat problem or air in the system. But this hasn’t resolved the issue.
I don’t want them to waste too much of their time if anybody has had a similar problem?
Any help appreciated.
Can these engines be run for long periods with the thermostats removed?
check for flow.
check the sea ****
was the raw water pump serviced?
Flybrain
Thanks, impeller housing and exhaust elbow are cool to the touch.
Water comes in through the drive, could it be a squashed hose or something in that?
Raw water pump wasn’t serviced.
Ayuh,...... Welcome Aboard,...... If the impeller wasn't changed, I'd start there,....
