kbait
Thread starter- Joined
- Nov 13, 2007
- 2,488
Working on a '58 7.5hp Johnson. Guy put a similar year 7.5 evinrude powerhead on after his failed (freeze plug w/model number is missing, so unknown year replacement powerhead..). He used the original head for cowl mounting and rigged up 3rd recoil mounting bracket/bolt. Runs fine, new impeller. Pumps plenty of water that is warm to the touch. Motor is overheating, as a little splash of water boils off the head while running. I shut it down quick.
Question- Is there any reason the evinrude powerhead wouldn't cool normally when attached to the johnson motor? I checked the water tube when apart and it was clear, and grommets are attached correctly. The old worn impeller was complete, so it shouldn't be a piece stuck in a powerhead port. Weird. Any help/insight greatly appreciated!
