a whistle in the remote control 703 Yamaha
yannk
hello,
My new boat was just been delivered.
She 's a cap camarat 6.5 with a Yamaha 150cv.
I have a noise, like a whistle, permanently in my remote control 703.
My Jeanneau retailer said to me that all the news yamaha delivered do the same noise!!!The noise is very stressing, and for me, it's not normal!
Have you an explication our a solution?
Thanks in advance.
yann
99yam40
Re: a whistle in the remote control 703 Yamaha
The only thing I can think of is the alarm buzzer is going off.
When does this happen?
when key is turned on without motor running?
With motor running after running for a while?
yannk
Thank you for your answer.
In fact, that occurs as soon as I switch on, as soon as I turn the key, when that the motor is off. That continuous when the motor is running.
All is new ( boat, motor).
99yam40
I do not know anything about a 150cv but most Yamahas have an alarm that is set to sound off by low oil level, high motor temperature, or if the safety switch (man overboard) is pulled with the key in the on position. But with the switch pulled the motor should not be able to run
