A reply to the question about steering
alanfox55
A question about adding a steering wheel was asked but that topic was closed so I thought I would answer that in a new topic. The answer to the question is yes you can add steering,it's easy,you can do it yourself and it doesn't take up a lot of space if you use the setup that I have. Everything you need is made by Uflex including mounting hardware. I believe Uflex calls their steering a helm. All it is a one piece bent tube that is mounted to your floor with four hand bolts. It has a flat plate where you mount your steering and a side plate where you mount your controls. They even make controls for this helm if you need some which I did. To this helm I have added numerous other items which include two gauges,light switch,kill switch and an electrical outlet. You can use this steering with your standard sib bench seat if you want to go the simple route. Here's some pic's and a video.
https://youtu.be/jUWdr1oXTdQ
