89nissanbassboat
Thread starter- Joined
- Mar 6, 2010
- 31
As some of you know I am looking at other alternatives while restoring my bass boat...after the rotted wood is removed I had a thought about just building up my transom with some heavy weight fiberglass cloth to add strength, maybe some 5oz cloth, about 3-4 layers and then use a good 3/16" piece of aluminum over everything to support the washers that hold my OB...does this sound like it would work?...after removing all the water pickups, all the wood was rotted out or soaking wet...I'm just trying to find a solution to a problem that many others seem to have...by the way, my transom is kinda funny shaped almost like a arrow head so it is not very wide or tall...I'm just not feeling good about replacing my transom with another piece of wood knowing that it will eventually seep in water again and then I'll be back to square one.
Any thoughts on the subject would be helpful as I would like to here from some experienced boat restorers out there on what you think about my permanent fix for a old problem.
Thanks
Thanks
