A few questions about boat project from a newbie
Lightnig
Well, here goes...
Before I get to my actual questions, I am going to give a bit of a background on myself and the project boat. My goal for this project is to end up with something that I can take the family out to the local lakes for a bit of weekend fun a few times a year. I don't have a large budget, so I don't want to spend more than I have to - but I am more than willing to spend the money to the job properly (but not necessarily top notch).
While I am new to boating in general (this is my first boat), I am strong in mechanical ability - welder by trade, with lots of layout and construction layout experience, and a little woodworking knowledge but no experience with fibreglass. The one thing I can supply in fair abundance is time and labour. My woodworking tool inventory is in short supply, I only have the basics and I don't really care to spend a couple of grand in specialty tools either. Again, If it necessary, I will get it, but only if necessary.
The boat is a 16' (actually 15' 6") calglass runabout. The hull is essentially good but has a couple of problem areas I will discuss later. There is no motor or interior, it is literally an empty hull with a floor and a cap.
This is how it sits today:
First of all, it needs a floor. The fibreglass covering the floor is completely delaminated from the plywood core.
This is no problem. I am confident that I can put in a floor thats better quality than the one it came with from the factory. Considering that I almost put my foot through the floor where the pilots seat should have been, I am positive the stringers need replacement too and I am planning to do them along with the floor.
While I was cleaning out the years of leafs, pine needles, and general lawn refuse from the interior, I discovered the hull does actually have a fairly good leak. It's right on the keel.
Here is the best picture of the damaged area I could get:
As you can see, this area has been a problem for a while as one of the previous owners attempted a repair(s???) before.
Another problem area is the Transom. While it does appear fairly strong, I did manage to stick a probe past/under the cap and through various holes and found that I could press the probe into the wood core fairly easily, so it appears that it needs a transom replacement as well.
So, here start the questions:
If I didn't say it before, I will now. The point of all these questions is for me to assess whether or not it is feasible and reasonable for me to complete the project and end up with weekend toy that is safe for me to take the family out to play. If this particular boat is not going to allow me complete the project in a reasonable timeframe (by next summer) for reasonable cost then I will give up on this boat and find a different project to pursue.
First of all, when I do the floor, what thickness of plywood should I plan on using? Normally, I would pull up and see what is already there, but I don't know if the presently existing material is original or not, or even if it is, was it correct to start with. Is 3/4" right, or do I need more/less? What about the stringers? (this is for purposes of planning a budget)
But, the keel leak and the transom are the greatest concern for me.
I lack the facilities to flip the boat to work on the keel, so whatever I do to fix this will be from the top side and on my back under the boat. Yes, it will be away from the trailer so I can get at the repair site.
I know it will be possible to make this repair, but is it reasonable to make this type of repair given the above conditions?
The Transom is the other issue. I don't really want to pull the cap, but I know that it will be necessary to repair it. While the wood core of the transom is soft, it is still a complete piece of wood.
I have read up on a few manufacturers that have products that claim to be able to stabilize and reinforce wood in this state by means of injectable adhesives. Is this type of repair feasible, or does this sound like a complete transom replacement? (I believe I already know the proper answer to this question already, but I guess I am just looking for opinions.)
What material thickness for transom, 1"?
And now for a question out of left field.
This boat is obviously an outboard hull.
But, since I will be replacing the floor and Transom, how much more effort would it be to convert it to a sterndrive? Nothing crazy, say a 4 cyl Merc. I know, I know, I said I didn't want to spend more money than necessary, BUt I really like the idea of an I/O rather than an outboard.
So, What is everyone's opinion? (And don't be worried about hurting my feelings, just say what you mean) Should this green landlubber pursue this project; fix up the floor, keel, transom, and find an outboard?
Or should I turf it and look for a different project; something that already has an I/O and doesn't need extensive repairs?
Or option #3, cut and section the hull, add a couple or three feet to the length, a foot or two to the beam, add a cabin, and throw in a pair of 350 ci inboards???
hahaha, don't answer that last one...
danond
Re: A few questions about boat project from a newbie
I think it's a terrible place to start as a noob boat owner. You won't be on the water for 1-2 seasons, and you will have about 2 to 3 times the money invested in that boat than you'd spend straight buying one that's ready to go.
Seriously. Boat restoration is expensive. There's no way to make it cheap.
rjlipscomb
That's not a restoration, it's a reincarnation.
1. Do you have the need for a "project". Yes, and you're on the right path. No, and you better start looking for a boat.
2. I would not convert it to an I/O. But, the more experienced on here will advise you on that.
3. You can buy or make a stand that will support the hull while you work on and under it without having to lay on your back.
4. Get it off that rusted thing.
5. The hull is mostly labor. The running gear, steering, cabling, etc. will get expensive since most of it will be new or reconditioned if you can find it.
GOOD LUCK:D
CheapboatKev
I admire your enthuisasm and know what it is to have a vision of "could be", but that hull is waaay beyond my level or budget. If it was given to you, you still aren't ahead..maybe a little..
I would strongly consider looking for a better foundation to build upon..Many of those fixes are major endeavors and not cheap..How do you feel about alum boats? Lots of em ot there reasonable and I have never heard of a rotten one..lol
Any way you choose to, best wishes..IF you go forward, there are many here that can walk you through this..It will be a long road my friend
F14CRAZY
Ensign
I would suggest finding a whole 'nother hull that already has an engine, controls, etc so you'd have something to start with
Rickairmedic
I hate to say it but I agree with the others here . I currently own 3 project boats .
1960 Cutter 14' runabout . This is the first one I will tear apart and put together it was a one owner boat and was pretty much complete including the 1959 Mercury Mark 58A outboard . This is the smallest of the 3 and also the easiest( cheapest ) to get on the water .
1964 Crestliner 16' runabout .this boat will most likely end up getting sold as it has no seats very soft floors and no motor .
1974 Larson 1700 Shark 18' .This boat needs lots of structural work ( new deck , stringers , most likely transom and although the interior is there its pretty much crap and not worth messing with . This boat will most likely end up being a winter project so I can get it on the water next spring with the familly.
I see boats everyday on my local craigslist CHEAP many that could be used for the season and then rebuilt in the $1000-$2000 range . There is a SWEEEEEEEET 19' Starcraft holiday locally for $1750 OBO which means 14 or 15 crisp $100 bills would most likely procure this boat ( problem is I am out of boat room ) . The only thing I can see that this boat needs is more seating as theres only 2 captains seats in it at the moment . With the current economy it isnt hard to run across some real steals if you watch and pay attention . I wish I had room for that Starcraft at the moment I would be all over it . Bob_VT even was nice enough to find me a decent Starcraft in his area that could be had for $500.00 it is a resto project but its mostly there.
Rick
jonesg
I'd do it, mine was worse and I had a small budget.
Pulling the floor showed more of a nitemare than you have.
I also did stringers and transom .
So if you decide to have a go, start like this, pull the cap and set aside.
Gut the hull, grind , clean and dry the problem area of the hull.
Lay a good patch, do it properly with succesive patches larger than the previous to spread the load. Use polyester resin without wax, order it online to save money. UScomposites.com is a popular supplier.
After you have a good interior patch start grinding the exterior of the problem area until its all gone and you start to see good glass.
Then build it back up again and finish with gelcoat if you want or just fair and paint to match.
Grind out stringers and replace, ditto on the transom.
It'll take 3 months working steady.
http://forums.iboats.com/showthread.php?t=320710
or junk it. I think its a good project, and I think you can do it.
As I said, mine was worse.
keepNitreel
I see boats everyday on my local craigslist CHEAP many that could be used for the season and then rebuilt in the $1000-$2000 range . There is a SWEEEEEEEET 19' Starcraft holiday locally for $1750 OBO which means 14 or 15 crisp $100 bills would most likely procure this boat ( problem is I am out of boat room ). Rick
Take the advice given to you, it's all good advice.
Rickairmedic
To give you another perspective on what your looking at to get that boat done.
Motor and controls $1000-$2000
Steering controls $200-$400
Guages $100-$200
Wood and fibrglass $500-$1000 minimum
Interior $500-$1000 minimum
Paint and supplies $200-$500 this includes sanding and grinding stuff
This gives you a minimum of $2500 and a maximum of $5100 invested and your more likely to go over the max than under the minimum not to mention many many many man hours doing all of it . This is all from a nebie who has been doing ALOOOOOOT of research.
Rick
ezmobee
Aluminum, aluminum, aluminum....
J. Mark
Try and find a windshield for that boat . . . that will tell you a lot.
Save your money and watch for a more manageable project. That boat is going to require a ton of work and a fair bit of money, so unless you are in love with the lines or have a reason to build up THAT boat, move on.
gunner1
What he said. Also look for something with a motor and controls.An aluminum boat with no interior and in need of a transom is a MUCH faster and easier fix. Here's a little crredo from my hot-rodding days: Looks don't make it go! What I mean is that if you found an aluminum boat that needed a floor and transom but was a little iffy on the outside, you could still be SAFELY up and running in a short period of time and paint it as time allowed.
ezmobee
This coming from two guys who basically bought the same ***-ugly Starcraft :)
Lightnig
Thanks for the candid remarks and opinions all.
Right now my current line of thinking is to turf this particular project, and find something else that doesn't require the large amount of work that this one does. The primary driver for this is cost. My own research indicated I would be looking at a total of $6-7k, which is right in line with the numbers jonesg quoted me.
The primary problem being a motor. Unfortunately, this area is really short on good quality second hand stuff. All the used motors I have found around here in the $1000 range (give or take a few hundred) tend to be real junk that all need to be rebuilt, and then prices jump to 3K + for a motor that is decent - and I have found very few of them at all.
As far as reasonably priced boats, I have found very few at dealers in the area that have suitable candidates. The only one I've really found is a '91 18' Glascon bow rider with a 4.3 mercruiser I/O for $8k. This one is a bit more than I would care to spend at this point, but does have most of the features I want. I have found a couple more on CL and similar listings in this area, but the descriptions lead me to believe that those boats are not much better than the one I have now, other than they have motors (that no doubt need rebuilding), controls and interiors (that likely need refurb). Like someone mentioned in the other thread of mine, they have spent a year getting their project to a point where it is in a similar state to where mine is now - which would really defeat the purpose of getting a different boat.
The good thing about the current project is that I can spread out the cost over the next year or so, as opposed to all up front. But, all that said, I am going to start looking at other options for a couple of weeks and see what I can find.
So, the possibility exists that I may still undertake this project, due to a potential lack of good used alternatives. If I am unable to find the right deal, then I will be going ahead with this one.
The more I think about it, the less monumental the various tasks appear. Just some really good planning should alleviate would go a long way to making it as painless as possible. I think most of my previous concern was due to doubt about working with Fibreglass, a material I have been unfamiliar with it, but the basic processes of performing each of the repairs is pretty much identical to what I do know - steel.
Rickairmedic, your comments in particular helped me get this through my thick skull, thank you. The process you describe to repair the keel is identical to what I would have done had this been built out of steel. Now that I can think in those terms, I can look at each task in this project and plan on how to go about doing it. I still have lots of gaps in my knowledge, and lots of questions about the particulars, but I can understand and foresee the general steps.
Lightnig
Actually, that is the one thing I do have for it. Well, mostly... The complete frame is there, but is missing 2 panes of glass, no big deal...
CheapboatKev
lol..there is some good news for ya!
At least that scratches the windshield off your major repair list:p
chrishayes
Oh brother, I feel for you! That is one sad boat(and trailer). That trailer is junks man. Even a good welder would sink some serious cash in that to get it up to par. Just check out the price of a keel roller for a trailer.
At the very least you could buy a neglected boat for a few hundred dollars that has all the major things$$$$$$$$$ and have the motor rebuilt(or DIY) and do the same stringer/transom/deck job. You would come in much lower dollar wise as you would be heading into it knowing that you were buying junk that needed rebuilt. SO, all you would need to do is make sure everything was there or that the things that are missing are at least available and not too $$much.
Think about it. You buy a motor from Joe smith for 3000$ in "running" condition. You do all your rediculous amount of work on your ready for the heap hull, you put in a really nice interior all the controls and gauges then you hang that Joe Smith motor on the back and fire it up. It runs great on the muffs in the drive. You load the fam up and head to the lake. You plop it in the water with your kids faces full of joy and excitement then you turn the key, she fires and you feel all warm and fuzzy. Then you drop her in gear and she dies! So you break your kids heart, drag it home and put a post on here for "what is wrong with my engine". You find out it is a gummed up carb that will cost a few bucks to repair. You do that then you realize that due to the gummed up carb, the motor has leaned out and scored the pistons. Now you have to rebuild the motor$.
Long story short. Buy a sad boat with no holes in the hull with a blown motor that has never been bored for a few bucks or "if you take it, you can have it" then rebuild everthing right off the bat. That will allow you to budget the whole things with no surprises. That or buy an aluminum boat since you are a welder. Good luck.
