A few engine questions!
mindblown
I am a woman who kinda knows my way around engines! I have an 86 205 V6. I have the engine out of my boat. Went to change oil, the oil pan was full of milky oil and the oil filter was full of it as well. I am not sure where water is coming in. The spark plugs look good. The engine runs good as well. Could the exhaust manifold (water intake) let water in? Read the manual, checked suggestions not sure where.
Re: A few engine questions!
Ayuh,.... Welcome Aboard,.... Sounds like a Freeze cracked block,... could be the intake water pocket as well....
mindblown
Should it smoke or anything like that? Which it has not. It runs good, sounds good!
Ayuh,... It's cracked 'tween the water jacket, 'n oil cavity,...
Got nothin' to do with runnability, nor cylinder compression...
Block off the block's water jacket, 'n pressure test with air,... drain the block 1st...
mindblown
It is worth it to fix and/or is it fixable?
Ayuh,.... Donno,... IF the block is freeze cracked,... a long block crate motor is 'bout $1800. or so,...
Bare long block...
Diagnosis will tell ya What's broken,... ;)
