A complete rebuild of Johnson V4 crossflow
spybot
I have my engine now completely stripped and will be rebuilding her very soon.
Is there anything i should be aware of when i start ?
I have the factory manual Will follow that but is there any tips you guys have ?
I have replaced crank seals checked all bearings in the crankshaft.
The thing that gets me is the factory manual only say's when reassembling the motor to use 2 stroke oil on everything. I have no qualms doing so,
But should the top and bottom bearings not be packed with OMC triple guard ?
Or is the 2 stroke more than enough for it ?
I know that for the rest of its running life the only lube it will receive will be via the 50/1 mix, so would it not be good practice to use the grease at this stage ?
Faztbullet
No as its not designed for internal usage and would be to hard for engine to wash out.
Honorary Supreme Mariner
Why would you want to use grease here ??----Are you replacing the check valve ( $$$ ) for the center bearing ?
spybot
Thanks for the input. I just assumed with them bearings they would have grease in them.
No racerone i am doing a complete rebuild of my engine.
Finding it hard to get hold of wrist pin needles over this side of the pond. I take it it is a good idea to change them.
spybot
What is the check valve for the centre bearing ?
Is that the locating pin ?
Some blocks have a check valve !!---Post picture of area where bearing sits.
spybot
Is the small brass thing the check valve ? If so how do i replace it ????
Correct,------That is the check valve.----You are learning a bit at a time I guess.
spybot
I am learning all the time from you guys.
All i know about outboards is what i have learned from forums and youtube.
Can you tell me what it does and how to replace it ?
Is it some sort of lubrication valve ? Will it unscrew with an easy out or is it pressed in ?
spybot
I cant see it on any parts manual ? Can it be cleaned out in the block ?
