toolsinbox
Thread starter- Joined
- Apr 22, 2009
- 187
Alpha one First gen.
Is it possible to change the trim sensor by undoing the the gimbel housing but leaving the shaft bellows attached?
Can anyone tell me what size and kind of socket I need to remove my Y exaust pipeing from inner transum housing? The bolt heads look like a sproket. I am not using the y pipes so may as well pull them out and install cover. By the way can I make a cover from 1/4 inch thick flat aluminum stock? Will that seal it up or do I need the exact part?
Thanks
Thanks
