Hi folks, hope you can help.
In 2010 NAMARANTA wrote the following post
"Hey guys need some help. Got a 1992 johnson outboard 150hp, v6, 2 stroke with optical ignition. Engine stalls after driving for awhile (maybe a hour) or once engine is hot. No sputter or warning, just instantly kills. Verified no spark when fault occurs. Engine will usually restart after sitting for a few minutes and may run for another 30 or 5 minutes before it needs to cool again. Installed new power pack and optical pick up, new pick up wouldnt work???? so reinstalled old pick up with new power pack. Engine ran perfect for 2 full, hard days on the water before the exact same problem happened again. Put old power pack in and was able to get it back to the dock. Inspected all grounds, connections and engine harness. Nothing. Inspected stator, flywheel magnets and alternator rectifier. Advised by an "expert" to replace stator and alternator rectifier with CDI new parts. Took boat back out and same issue occured within 45 min. No miss fires or rough run, just instant cut out and usually will restart within 20 min of resting. Any suggestions?"
As near as I can determine my 1993 Johnson 150 is doing exactly what his engine was doing. Starts fine, idles smoothly, run it at normal cruising speeds or wot and it may shut down as if you switched of the ignition, will not restart right away, 5 to15 minutes later it will restart and run normally, sometimes it will run OK for hours but also maybe just a few minutes before it fails again.
NAMARANTA never posted a solution if he found one. Anybody out there got any clues before I start replacing a lot of expensive parts?
