99 Johnson V-4 90hp Skipin"
Flat-Out
My motor is skipping at high speeds/rpm of about 4000. I replaced the plugs and test ran for about 30 minutes and it still sputters at high speeds. I am thinking a fuel/water separator is my next option. Boat has not been used alot in the past 3 months, but I had started it from time to time and had the fuel topped off. Any suggestions? Thanks Rick
D
DJ
Guest
Re: 99 Johnson V-4 90hp Skipin"
Rick,<br /><br />How does it run above and below 4K?
Flat-Out
DJ, <br />The motor starts fine, runs perfect at idle up to about 3500 rpm. It will run ok then every so often I notice a skip/sputter over 3500-4500 rpm!<br />Thanks for the response...
Flat-Out
DJ, <br />Thanks, I just got off the phone with West Marine and will pick one up tonight and install tommorow...stay tune for further developments. Thanks again, Rick :)
Flat-Out
Installed a fuel/water seperator yesterday and ran the boat for about an hour and everything seems to be AOK...Thanks again for all of ya'll's help...Tight-lines
