99 Johnson 90HP V4 J90PLSSE
sanderssk
We spent a great day out fishing a couple of days ago and we were headed back in at top speed. All of the sudden the engine stopped in the middle of the ICW. It was as if I had accidently hit the key. I checked the oil tank because I suspected it may have cut out on low oil level and it was low. I keep extra oil on board and refilled it, but I could not restart the engine. Any suggestions?
Thank you!
crb478
Re: 99 Johnson 90HP V4 J90PLSSE
Check for spark on all four cylinders, might as well verify compression also and then check back with those results.
RWYoungblood
I had the same problem today with my 2000 Johnson 90hp model# J90PLSSE. Had to be towed back to the landing. Tough day on the lake! What problem and fix did you find? Thanks for the help.
hidef
Please start you own topic this was posted 3 years ago.
