drewherring
Thread starter- Joined
- Mar 24, 2010
- 1
Got this motor new and it has run great for 10 years. Recently started cutting off at idle. Starts cold and runs wide open great but once it warms up it refuses to run at low RPM and is very hard to get started. When it does start it will cut off after a few seconds if you don't gun it. So I bought a carb kit and figured I'd take the carb off and soak it and blow it out. I figure that should fix it. Only problem is I can't get the carb off! One of the mounting bolts seems to be blocked by the electric starter. Can't figure out how to remove the starter either. Someone please help with getting this starter off. I can't figure out how to get to this bolt of doom! Thanks in advance!
